Projector and rented property
Discussion in 'Home Cinema Buying & Building' started by pborojon, Feb 21, 2013.
  1. pborojon
    pborojon
    Jun 4, 2012
    3,307
    Newton Abbot
    +252
    Hey all,
    Looking for some help/advice really want a projector but not sure if there is a way to put the screen up without having to mount it to the ceiling etc. in an ideal world I'd go for a remote control screen but guessing that's not possible? I can buy a stand for the projector to go behind the couch so that's not an issue just struggling with the best way to get a screen up :( cheers
  2. Linx08
    Linx08
    Sep 29, 2008
    1,622
    Whittlesey, Cambs
    +191
    You can get pull up screens that have their own feet, it wouldn't be the greatest but certainly pretty cheap and easily to put up and put away again.
    Kind regards
    Linx
  3. pborojon
    pborojon
    Jun 4, 2012
    3,307
    Newton Abbot
    +252
    Yeah had a look at them suppose its the best option. Cheers for the reply :)
  4. Linx08
    Linx08
    Sep 29, 2008
    1,622
    Whittlesey, Cambs
    +191
    No worries, hope it works out for you.
    Kind regards
    Linx
