Projections screen(s)
Discussion in 'Projectors, Screens & Video Processors' started by Vassago_m, Jun 26, 2003.
  1. Vassago_m
    Vassago_m
    I am very keen on buying a projector and as I dont have much money I am looking at the Pansonic PT-AE100E, but I am unsure on what screen to go for.
    I am looking for one which will either be a manual pull down or electrical as my room is more than big enough to host a 12ft screen.
    I am open to suggestions about projectors as well as I can push to £1800 on a projector and £500 for a screen, but I am interested in this one due to its 16:9 (true) ratio.
    Cheers for any come back....
    Vassa
  2. Kramer
    Kramer
    12' - forget it with an AE100 or any other LCD PJ (any PJ in fact.
    With a budget of £1800 you really should be looking at a high res PJ - 1280x720 min.
    The HS10 is available @ approx £2k & will happily project an 8' pic. It's got a high enough pixel density & fill ratio to go bigger than this, but obtaining a bigger screen will be a problem, especially on your budget.
    With £2.3 to spend in total, there's no point considering the AE100.
    :smoke:
  3. Vassago_m
    Vassago_m
    So the AE100 is not really that good ?
    Can it throw a picture on a 6 foot screen ?
    the HS10, is that the Sony?
    1280x720 ? Are u meaning the pixel def, as the pansonic has, well I dont know, and I'm even reading the spec at the panasonic web site (DOH).
    I must admit I'm a noob, and need educating, even though I buy home cinema mags nearl every month.
    Well cheers for the come back and I now have a few more things to think about.
    Cheers Kramer
