Projection Screen
Discussion in 'Projectors, Screens & Video Processors' started by tom_nieto, Jun 1, 2004.
  1. tom_nieto
    tom_nieto
    May 21, 2003
    427
    Brighton
    Ok, so I've decided that a Panny PTAE200 will rock my world, and I've just ordered one, whoo! Although this does leave me quite poor :p
    Anyhow, I'm just wondering what to project it on to. Screens seem awfully expensive, and I'm wondering if a white wall will suffice til I can either make one out of a white bedsheet or find a suitable one. The room that I'm going to be projecting it in next year is enormous and I could in theory have about 5m throw distance which could in theory give me a 4m diagonal screen. I think something about 3m would be more realistic.
    Firstly could you lovely lot give me some places to buy decent but not so expensive screens from.
    Plan B as it were would be to make one out of a bed sheet (would white be fine?). I'm thinking about getting a large one and cutting it down to size. I want to get a metal pipe or a heavy bit of dowel and sew it into the bottom of the sheet, so it would effectively make it flat by stretching it a bit. I could then have some form of wall/ceiling mount attached to the top. I would then mask it to my desired size and paint a black border.
    What would you recommend?
    Tom
  2. dek1965
    dek1965
    Jan 20, 2003
    389
    Heysham
    +6
    paint screen on wall with dulux icestorm 5 or 6, then paint your black borders, i did this for a mate who also has an AE200 and the pq was excellent
  3. Chibouk
    Chibouk
    Oct 5, 2003
    553
    Darkest Lancashire
    +10
    You could always make your own screen. Mine cost me about £25 to make. Search this forum for more information :)
  4. tom_nieto
    tom_nieto
    May 21, 2003
    427
    Brighton
    As it's rented accomodation I don't think that would be an option, although it's definitely good to know that paint is fine, although you used matt paint right?
  5. dek1965
    dek1965
    Jan 20, 2003
    389
    Heysham
    +6
    you could paint a piece of mdf and mount it on the wall, as for the paint there are loads of satisfied (icestorm) users on these forums, dulux icestorm is a matt emulsion
  6. tom_nieto
    tom_nieto
    May 21, 2003
    427
    Brighton
    I wonder if I could buy a big piece of black fabric and paint it with the ice storm paint that you speak of. I would get black borders and it would hopefully be roll up, although I think it would probably crack if I rolled it... hmmm...
  7. dek1965
    dek1965
    Jan 20, 2003
    389
    Heysham
    +6
    some folks on here use blackout blinds (ikea tuplar is popular) they are cheap, roll up so can be hidden easily if required and are supposed to give a good pq, use search (blackout blinds) if you are intersted in going down this route
  8. jamiev
    jamiev
    Jan 4, 2004
    924
    +35
  9. booth1976
    booth1976
    Dec 12, 2002
    829
    +13
