Projection distances Sony hs 20
Discussion in 'Projectors, Screens & Video Processors' started by Jas, Dec 1, 2003.
  1. Jas
    Jas
    Jul 14, 2000
    87
    Lancs,Wigan
    Hi does any one have the Sony hs20 projector/ manual , I am considering one myself but am unsure which screen size to buy as i do not have the Sony manual. Could you please tell me as per manual what are the min and max projection distances (ie front of lens to projection surface) for a 92" diagonal wide screen (80" wide bottom left to right of screen)or a 83" diagonal wide screen (72" wide bottom left to right of screen). I am hoping to use the projector with 0 zoom mounted on a table or ceiling mount.
    Also does the Sony manual express the screen size as diagonal measurment or width of screen measurment as per my sizes above.
    Or if some one has the time perhaps the full chart as per manual would be useful also.
    many thanks for your help
    Jas
  2. loonatic
    loonatic
    Jan 4, 2003
    1,877
    41
    Springwell Village, Gateshead
    +16
  3. andy572
    andy572
    Dec 4, 2002
    361
    Oop North
    The model is listed in Projector Central's projection calculator if you want a quick (and graphical :clap: ) answer.
  4. Kane D Williams
    Kane D Williams
    Jan 24, 2002
    750
    Nr London
    +10
    Just realised I need a longer throw lens for the HS20. Does one exist and can it be fitted instead of the standard one?
  5. Robbie Gnome
    Robbie Gnome
    Saw this thread and thought I may be able to help. Considered buying the orginal HS-10 but had the same prob you have Kane D Williams. Sourced a Short Throw Lens SONY VPLLCW10 but at £ 790.00 plus import and VAT it started to look like a no go. Have confirmed the same conversion lens is usable on the HS-20. It's up to you. Makes you sick to think that you can get the same type of lens for the HS-2 for £130 inc VAT and import!! Doesn't make sense. I have been using this cheaper lens with my HS-2 and if anyone is considering getting one I would 100% recommend fitting it. Will be buying a HS-20 when we move, will make sure we have the right throw distance in our new living room though. Good thing I have an understanding girlfriend who understands about my Home Cinema Addiction:)
  6. Kane D Williams
    Kane D Williams
    Jan 24, 2002
    750
    Nr London
    +10
    Cheers Robbie
    I can ceiling mount and then it is not a problem, apart from the light fitting!
    I still have to decide between the AE500, HS20 and the Z2!
  7. fozziebear39
    fozziebear39
    Jan 3, 2003
    993
    Newton-le-Willows
    +43
    Hi Jas, 2 Sony projectors in one crap town :) At one point I wanted a short throw for my HS10 for a bigger picture but I am going to put it through the wall instead...
  8. Jas
    Jas
    Jul 14, 2000
    87
    Lancs,Wigan
    Thanks Loonatic
    Have downloaded pdf file in english 78 pages:eek:
    Thanks to all replies.
    Regars Jas
