Projection Advice Please .....
Discussion in 'Projectors, Screens & Video Processors' started by AndyBlac, Jan 5, 2002.
  1. AndyBlac
    AndyBlac
    Dec 24, 2001
    40
    Hi all,
    I have just recently bought myself a Toshiba SD-900E DVD player for use with my Rear Projection TV, only to find out that the TV does not support Component-Progresive but only Component-Interlaced.
    So I am thinking of buying myself a Projector so i can benifit from Progressive scan DVD, But I know nothing about Projectors at all. So any advice would be a great help. The only requirement I have is that the Projector must have a Component-Progresive input.
    I also know that they are expensive (£1,200 +). My buget is about £2000 or so.
    Thanks for any Help you can give.
  2. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    Tread carefully.
    You are . trying to buy a projector to work with your new DVD player is like trying to buy a car to go with your new driving gloves
    £2000 is the bottom of the PJ market. and finding one that will competely display PRogressive PAL and NTSC will be tricky at that price point.
