Projecting a Small Image
Discussion in 'Projectors, Screens & Video Processors' started by Nickyrboy, May 15, 2005.
  1. Nickyrboy
    Nickyrboy
    Feb 25, 2005
    71
    11
    Bristol
    As CRT projectors age and the tubes became not as bright as they once were is it possible to greatly reduce the projected image size and increase brightness. I have a Sony 1040QM currently projecting a 100" image but it's not what it once was, if i make my image significantly smaller by moving the projector closer to the screen (and obviously setting it up again) will the image get brighter or am i barking up the wrong tree.
    Nick
  2. Godfather
    Godfather
    Feb 12, 2001
    2,345
    63
    Edinburgh
    +225
    You're not barking up the wrong tree. The same projector firing onto a smaller screen will produce a brighter more punchy image. So I think it's worth trying if you want to squeeze a little more life out of your projector.
  3. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    Inverse square law.
    If I recall half the projected distance and you will get 4 time the amount of light
  4. bxd
    bxd
    Oct 17, 2001
    1,487
    Southampton
    +134
    While the Sony 10xx projectors will go up to 100-250in, they are probably at their best with a 72in (4:3) set up. Remember that you'll have to adjust the lens 'spacer' rings and the tube spacers from 100 to 72in.
    Brian
