juliushibert
I'm looking for a budget projector (<£500) to go in my bedroom. Looking for recommendations and guidance or if it's a stupid idea for this low budget?
A little research and I've found a few potential shortlisted projectors, but not fixed on getting any specifically.
Background / usage
Questions
Background / usage
- It'll only be used occasionally for late-night TV viewing or the odd movie. Probably only 1-4 hours a week use, if that.
- There's one large wall in the room that will be projected onto, it’s painted off-white. I don't have any plans to put in a projector screen.
- There's one window with curtains and the room gets relatively dark but not pitch black.
- It'll be used for streaming, probably with an attached Amazon or Google device.
- I'll build a small shelf above the bed headboard to mount the projector on.
- If the projector has a decent speaker that's a bonus, but have a few Bluetooth speakers in the house that I can spare to link it up to.
Questions
- Should I look for a min. lumen / ANSI rating?
- Is 1080p sufficient? Most content being streamed will be 1080p, 20% will be 4k, but not too bothered about a downgrade in quality.
- Is there anything else I should consider or be aware of?
- Is a projector with this budget and usage a waste of time?
