Project Gotham 2 Screenburn
Discussion in 'Plasma TVs Forum' started by tigermad, Jan 15, 2004.
  1. tigermad
    tigermad
    Jan 2, 2004
    5,925
    Bedfordshire
    +516
    I have read the many posts on here with problems concering screen burn.
    I purchased PG2 yesterday and made sure I only played for 2 hours at a time. Sure enough the rev counter was burnt into the screen when the Xbox was turned off. This disappeared after a few minutes watching Sky.
    Then later in the evening it happened again (it seems to be the rev counter).
    My question is, if this was played only for a few hours every evening, will it eventually permanantly burn the screen and not disappear?
    (By the way, the contrast settings and brightness are turned down as suggested)
  2. loonatic
    loonatic
    Jan 4, 2003
    1,925
    41
    Springwell Village, Gateshead
    +16
    What plasma do you have ?
    I have played F-Zero on my gamecube for a couple of hours and have not noticed any residual image on my panny.
    However, when I had my pio 433HDE I did notice that when I hooked up my PC it only took a few minutes before the start menu/task bar created a residual image which did disappear after a few minutes of normal TV use.
    The panny does seem to be a bit more resiliant than most.
    Cheers, Lee
  3. tigermad
    tigermad
    Jan 2, 2004
    5,925
    Bedfordshire
    +516
    Sorry, forgot to mention. I have a Pioneer 434
  4. wiped
    wiped
    Oct 9, 2003
    52
    home
    I've played PG2 alot!! on my 434 and i have no burn in issues.
    When the resudial image dissapears after playing you are back to square 1 again so there is not problem to pay again and again and again...
  5. manc
    manc
    Apr 3, 2003
    151
    19
    There is always residual images left on my hitachi pma400e After I have played up to a good few hours at a time and these images have always gone within a few seconds of normal use.
    I have grown more confident as i have used my plasma, at 1st I bricked myself thinking i had wrecked my display - I no longer worry. :)
  6. ziocleto
    ziocleto
    I've played it too with the same plasma.
    The HUD can be quite annoying, but never noticed any residual images, even playing for few hours the same time attack track...
  7. sdemmery
    sdemmery
    I too have a pma400e & play alot of PGR2 No problems here either. I do get the black top & bottom bars left on the screen after watching a Widescreen DVD but it disappears in seconds of watching sky.
    Stu
  8. AVWotcha
    AVWotcha
    Dec 3, 2002
    54
    My question is, is it actual "burn" or is it simply a memory effect ? and what causes it ?
  9. Nike
    Nike
    Feb 27, 2001
    667
    bournemouth, UK.
    +20
    It's not burn. Screen-burn is permanent and can not be removed by watching TV for a few minutes.
  10. AVWotcha
    AVWotcha
    Dec 3, 2002
    54
    So some kind of memory effect or hysterysis. I guess like on a nicad battery. question is why ?
