Project 111 Debut Turntable
Discussion in 'Hi-Fi Stereo Systems & Separates' started by WALT, Mar 31, 2016.
Tags:
  1. WALT
    WALT
    May 24, 2008
    38
    great turntable stopped giving output. Checked out the control box screwed to the bottom and the green right channel return wire had left its solder. Just need to know which fittings it needs to be soldered to.
    Thx
    Tony L
