Progrssive Scan input?
Discussion in 'Plasma TVs' started by mivvi, Feb 11, 2003.
  1. mivvi
    mivvi
    Have a Sony plasma 42" PFM42B1. I am purchasing a new DVD player and think im going for the Limit 9000se. How do I make the most of the Pro Scan output, does it come out of the scart socket on the player or is it a seperate output? Also how do I connect it to the plasma? I have a 15pin VGA input, s-vga and composite. Any help would be great!
    Is the Limit my best choice or the Tosh sd520?
  2. jmack
    jmack
    progressive scan uses component imputs you will have to use this output on your dvd player,
    i think some do progressive on the 15 pin vga but i dont think the limit 9000 has this output
  3. mivvi
    mivvi
    Thanks for the info JMack, I will look a bit further into it. Thanks again!
