Progressive Scanning!
Discussion in 'LCD & LED LCD TVs Forum' started by nokiaman, Apr 29, 2005.
Tags:
  1. nokiaman
    nokiaman
    Hi i'm getting a HDD/DVD recoreder, Sony RDR-HX510 which is a progressive scan player and i'm getting a LCD Tv (Sony KLV-L23M1) just wondering does the tv have to be proressive scan also? its a HD screen.
    Thx
  2. SteveW70
    SteveW70
    nokiaman,
    The Sony LCD is PAL Progressive enabled.
    See here: http://www.sony.co.uk/ShowProduct.do?site=odw_en_GB&category=TVP+Flat+Panel+TV&product=KLV-L32M1
    EDIT - Sorry wrong link thats the 32" :oops:
    Just checked the spec for the 23" and it doesn't look like it is.
    Maybe a call to sony is in order to clarify.
    Sorry !!
  3. nokiaman
    nokiaman
    Hi thx for that steve, i couldn't see it on the website either but i've seen it somewhere that says it does but i cant find it now or if i was just dreaming lol.
    Just mailed sony to see if they can tell me.
