progressive scan
Discussion in 'Blu-ray & DVD Players & Recorders' started by -Jay-, Jul 30, 2002.
  1. -Jay-
    -Jay-
    Jul 26, 2002
    4,934
    Kop End
    +135
    looking to buy a tv&dvd do both have to be progressive scan.to get progressive scan.
  2. Kirk
    Kirk
    Jul 2, 2002
    309
    Somewhere on t'internet
    You will need a souce and Display device with Component inputs.
    The source device (the DVD for example) should be able to output Prog Scan in whichever flavour is required (NTSC,PAL or Both...which is what I want and is a tad difficult to acheive at this point).
    The TV just needs to be able to accept the Prog Scan signal via Compnoent connections, it does not need to do the processing itself.
    Just to through some more complexities, some TV's such as some Sony's etc do Digital Processing on 100Hz sets which give similar results to Prog Scan...................
  3. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,686
    UK
    +115
    Panasonic have just released a new TV with component inputs which supports both PAL and NTSC prog scan...wow!!!!;)
    32PS40 is the model number I think...
    Check out the latest copy of What Hifi for a top review...
    JJ
  4. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,912
    71
    50 Rue St Georges, Paris.
    +32
    Panasonic TX-32PH40
  5. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Component inputs are NOT sufficient, you need a PS capable component input at the display!
    That is correct. :)
  6. ricdiggle
    ricdiggle
    Odd though,
    The panasonic accepts both NTSC and PAL prog from my Denon 2800 but still puts itself into prog scan mode.
    This seems very odd to me. The Denon is outputting prog scan and the panasonic is converting it again before displaying it.
    It clearly says progressive input and progressive scan mode.
    Maybe this is why my tv broke after 8 days?
