Progressive scan
Discussion in 'Blu-ray & DVD Players & Recorders' started by sharper, Jul 25, 2002.
  1. sharper
    sharper
    Jul 24, 2002
    607
    SW London
    +11
    Is it worth changing DVD player for 1. component and 2. progressive scan? I’m looking at one of the Toshiba’s when they come out. Will be running through Panasonic plasma, about to order the plasma.
  2. nigel_williams
    nigel_williams
    Jan 5, 2002
    447
    South London
    +3
    Component will give you a crisper/sharper image although a good RGB connection can be comparable (at least that's what I've heard).
    In my opinion, progressive is where you'll see the most significant image improvement, especially on large screens. The Toshibas only handle NTSC disks though, PAL progressive is much harder to come by so it depends how many R1 disks you have.
  3. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    If you go progressive it will naturally be via component and should give you a better picture.
    Component alone will not give much of an improvement over RGB.
  4. Oblivion
    Oblivion
    Feb 23, 2002
    524
    Milton Keynes
    Sharper - Check here for some examples of Prog Scan over interlaced.
    Paul
  5. BIONIC MAN
    BIONIC MAN
    Jun 26, 2002
    1,002
    Nasa
    +45
    Yeh but don't you also need a Tv with Progressive Scan ? ? ,
    Otherwise you still won't get the best picture just via the
    dvd player with Progreeive Scan conneted to the Tv via Component ? ? ,
    This is what I have herd
    :D
  6. Gordon @ Convergent AV
    Jul 13, 2000
    14,209
    +3,045
    To benefit from a progressive scan DVD player you need a monitor that will accept such a signal. You do not need that display device to also have any de-interlacing facility itself....so you heard wrong....
    Gordon
  7. BIONIC MAN
    BIONIC MAN
    Jun 26, 2002
    1,002
    Nasa
    +45
    Gordon
    So if I connect a SD900E to my Tosh 32ZD09B Via component it
    will play region 1 dvd's in full Progressive scan mode and the picture should look COOOOOOl As Ice ,
    Many thanks for your help
  8. Gordon @ Convergent AV
    Jul 13, 2000
    14,209
    +3,045
    I do not know whether that television is capable of accepting a progressive scan input signal. If it's the same as Oblivions then I guess it should...You'll know if it can't as you'll get a double image probably...or nothing at all.
    Gordon
  9. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,906
    71
    50 Rue St Georges, Paris.
    +32
    I have tried my Denon DVD-2800 through the component inputs of a friend's Toshiba 32ZD09B. Although the picture came through fine when not Progressive, the screen became blue mute when Progressive was selected.
    This television won't accept a PS signal, the PQ through the component inputs looked slightly better than through RGB scart.
  10. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    I think you caused a missunderstanding here: When he said "Yeh but don't you also need a Tv with Progressive Scan ? ?" I guess he didn't mean a de-interlacing circuit like e.g. Sony's DRC but instead PS compability as you described.
    Thus the display needs to support progressive scan, but it does not need to 'process' the image any further.
    So he heard correctly ... ;)
