Progressive scan
Discussion in 'Projectors, Screens & Video Processors' started by Ricky27, Apr 25, 2002.
  1. Ricky27
    Ricky27
    Feb 8, 2002
    1,971
    Norwich
    +217
    As a few of you know im a recent convertto PJs and was thinking about this progressive scan thing,would it be worth getting as i only actually buy PAL discs?
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    It's well worth it if you buy either an Arcam fMj Dv27 or the Arcam DiVA 88 with PS module.
    They are £1,600 and £1,350 respectivly.
  3. Ricky27
    Ricky27
    Feb 8, 2002
    1,971
    Norwich
    +217
    What about the tosh sd510e?
  4. Peter Webb
    Peter Webb
    Not to mention the Nintaus PDVD-N9769 :D
  5. nigel_williams
    nigel_williams
    Jan 5, 2002
    447
    South London
    +3
    Definately worth it. It makes a big difference to the picture quality on the big screen.
    I've been holding off buying for a few weeks but as there doesn't seem to be anything else around that does PAL Progressive so well, it has to be the Arcam DV27 FMJ.
    I posted my findings when I borrowed one to test a few weeks back with my Sony VW11: http://www.avforums.com/frame.html?...owthread.php?s=&threadid=33657&highlight=DV27
  6. Kramer
    Kramer
    You should look into a HTPC (Home theatre PC).
    Should cost you about 500 quid, but you need to be fairly PC literate to tweak or get the best from it.
    Fully remote controlable with an IRman & Girder software, but, without doubt, IMO, the only way to extract the best from the AE-100.
    Lots of info in the HTPC forum.
