Progressive Scan???!!
Discussion in 'General TV Discussions Forum' started by MiamiLoco, May 21, 2001.
  1. MiamiLoco
    MiamiLoco
    I have a 32" Wega with no PIP and the bottom speakers (What do I need good speakers and PIP if I just hook it up to my Receiver??). When I watch DVDs I always use the ANAMORPHIC feature. My DVD player has PROGRESSIVE Scan capabilities but my WEGA TV doesn't. Should I just get a NEW TV (that has progressive scan capabilities) or is it not worth it and just stick with my WEGA??
  2. lmccauley
    lmccauley
    Oct 24, 2000
    3,563
    Newcastle
    +347
    Difficult to say, as my knowledge of the American TV market is limited. In the UK there are very few (possibly 2 via VGA inputs) TVs that will accept progressive scan inputs. I believe that HDTV sets in the states should be able to take the 480p signal from a progressive scan DVD player. Whether this is worth the upgrade would have to be determined by you getting a demo.
    Hope this helps,
    Liam
  3. MiamiLoco
    MiamiLoco
    Well right now my WEGA is connected with component video. So the real question A)WEGA TV with the component video B)Buy a new TV so I can use my PROGRESSIVE SCAN?? There is a SAMSUNG 27" 16:9 that has Progressive scan, I have this TV in mind. Can I get a recommendation please
  4. lmccauley
    lmccauley
    Oct 24, 2000
    3,563
    Newcastle
    +347
    Jose,
    I think you may have more luck posting this query to the AVS Forum (http://www.avsforum.com/), as the HCCO site tends to be more UK focussed (it being a UK magazine).
    Cheers,
    Liam
