Progressive scan via Amp?
Discussion in 'AV Receivers & Amplifiers' started by sapkan, Oct 13, 2004.
  1. sapkan
    sapkan
    Jul 8, 2004
    496
    +4
    If I route a normal video signal (from a satellite receiver box, either via s-video or composite) through a receiver that has component upconversion feature does this make the signal output from the receiver into a progressive scan signal?
  2. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,191
    2
    +3,664
    No- interlaced in = interlaced out unless you happen to have a Yamaha DSP Z9. By the same token, if you put a progressive component signal through an amp, it generally comes out the other end progressive as well.
    Ed
