Progressive Scan through an amp..
Discussion in 'Projectors, Screens & Video Processors' started by museumsteve, Sep 26, 2001.
  1. museumsteve
    museumsteve
    Jan 28, 2001
    7,925
    4
    Nth Hampshire
    +1,076
    I use my AVCA1SE as my home cinema hub (like you do) and was wondering if I use a progressive scan unit (DVD or GameCube) connected through the amp's component inputs, will the signal be received as progressive scan by a projector (if it supports PS of course)..<br />I'm really asking if the signal is tampered with when travelling through the amp...<br />Thanks in advance..
  2. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,602
    7
    167
    Birmingham, UK
    +10,466
    Does the amp have component outputs?
  3. Gordon @ Convergent AV
    Jul 13, 2000
    14,207
    +3,042
    I'd check with Denon but I'm pretty sure the component switching in the A1SE has enough bandwidth to switch 480P without loss. It may even have been designed with Hi-Def TV in mind in which case you'll definately be OK.
    Gordon:
    Check with Denon though to be sure
  4. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
  5. nfordenfield
    nfordenfield
    Apr 9, 2001
    625
    19
    Kent
    This was heavily debated when the amp first arrived, i recall that yes i could deal with bandwith of 480p even 720p but was not designed for 1080p.
    If i can remember where it is, i'll post the hyperlink.
    Nathan
