Progressive scan results in squished picture
Discussion in 'Projectors, Screens & Video Processors' started by Xaximus, Jun 25, 2004.
  1. Xaximus
    Xaximus
    Disclaimer: I'm a noob.
    I have an RCA D52W20 television (widescreen), and just picked up an inexpensive RCA RTD250 home theatre package (receiver/DVD combo unit and 5.1 speakers). The problem: when I enable progressive scan for watching my Band of Brothers DVDs (widescreen), the picture is squished so that there are black bars on the top and bottom of the screen. Keep in mind that my television is widescreen, and supports progressive scan. There is no such problem when progressive scan is disabled, and the picture is normally displayed in widescreen without any black bars. Does anyone have any suggestions or insight? Thanks very much.
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,215
    +3,068
    I think that you should post this at www.avsforum.com
    This is a european forum and we don't have much experience of RCA products over here.
    Check that your DVD players set up menu is at 16:9 for display type and then when you play back the DVD check the TV's aspect ratio is set correctly to show the image in the correct geometric setting. This may be called "anamorphic" or "16:9" on TV
    Gordon
  3. Xaximus
    Xaximus
    The DVD player is indeed set for 16:9. Usually while watching something, I can change the TV's aspect ratio. However, I noticed that while the DVD player is in progressive scan mode, my TV's aspect ratio is frozen (and doesn't display what the current aspect ratio is, which I've never seen it do before). Weird stuff. In any case, I'll post over in the avsforum.com... thanks for the tip!
