Progressive scan question?
river123
Does the pioneer 436sxe have progressive scan if so which connections should be used from my progressive scan dvd player to which scart input on my plasma and which video out setting should be set on my dvd player?At the moment i only have sky plus and not hd.
use a component lead as scart does not do the progressive scan and make sure the dvd player has the prog scan setting turned on in the setup menu things
dan4805
To watch a progressive input on the SXE you must connect the Componant cables to Input 2, IMPORTANTLY you must also connect a scart lead from your DVD to Input 2 ( this is for the Audio Input.....Ignore this connection if you are running the sound through a dedicated AMP ).
Then go to menu, put the input to input 2, then go to :-
MENU - OPTIONS- INPUT SELECT and select COMPONANT
hope this helps
Dan
