Progressive Scan Playback on Tosh 36ZP48/RD-XS32
Discussion in 'TVs' started by L00py^, Jan 13, 2005.
  1. L00py^
    L00py^
    Sep 23, 2004
    129
    I have just got a new 36ZP48 telly & RD-XS32 DVD recorder/player and was after some help please. If I select progressive scan on the TV option menu then press the progressive scan button on the RDXS-32 remote control, and then play the DVD. How can you be 100% certain that the system is actually displaying progressive scan on playback on a DVD?
  2. spocktra
    spocktra
    Nov 22, 2004
    2,014
    48
    worcester
    +40
    Some of the remote functions of the tv will not work when progressive is enabled.Digital scanning being one.
  3. JayCee
    JayCee
    Jan 20, 2004
    20,346
    Lanarkshire
    +1,954
    What "remote functions" won't work?
  4. L00py^
    L00py^
    Sep 23, 2004
    129
    Yeap thanks, I got it sorted now, progressive is via ext 4(component cables) if you have this setup you can not get an option to change the scan display type.
  5. Nivelo
    Nivelo
    Yeah, as you stated, if you run Progressive on the XS32 you don't see an option to change the display type on the TV. I would be interested in whether you can see more flicker when selecting progressive than through the Active or Natural modes (especially on predominately light scenes).
    I have the same setup and the flicker is worse when using progressive scan when the scene being displayed is quite light.
    Andy
  6. L00py^
    L00py^
    Sep 23, 2004
    129
    Well for example on Star Wars at the start when the text scrolls down, I get slight flickering on the text using scart, on component playback get no flickering at all.
    And also deffo improves the playback on component alot.
