Jon Weaver
I have recently bought a DVP-NS930 player specifically for its Progressive Scan capability. I am connecting it to my Toshiba 27WP42 Plasma (Panasonic Series 5) and on a couple of occasions recently noticed a strange 'phenominon'.
Its quite hard to explain what I mean, but picture appears to be made of odd and even horizontal stripes.
The odd stripes are from one frame, the even stripes are from the next.
So, when you have fast movement, the picture looks 'stripey'.
So, for example, if you had an object moving across the screen, it would like like this:
*ignore the dots, as this is the only way that I can insert a 'space'
Where as it should look like this:
If I then stop the disk, go into the menus and change to 'Interlaced', the problem goes away.. But more worryingly, if I then change it back to 'Progressive', its not their either. The picture is now fine..
I havn't worked out how to get it in this state, but now that I have noticed it, it seems to happen regluarly.
I am not sure if this is a problem with the DVD player or the screen, so I am going to do some more tests later, but it certainly looks like a 'bug' rather than a fault.
I wonder if anyone has any ideas whats wrong
