Progressive scan output from a PC
Discussion in 'Projectors, Screens & Video Processors' started by Dalwinder, May 29, 2003.
  1. Dalwinder
    Dalwinder
    Dec 21, 2002
    23
    3
    I was wondering if it would be an idea to purcase a quiet PC with a small foothold i.e.
    mini-itx
    and to equip it with say a
    RealMagic XCard
    I am not sure but I think the progressive scan it handled by software rather than hardware. Is this bad?
    Has anyone any advice or experience in this area?
    Basically I wish to purchase a lcd projector (Pana AE300) in the near future and I would like to provide the projector the best input signal. I may be miles off here so please advise this newbie.
    Dal
  2. salacious
    salacious
    Nov 2, 2001
    46
    Scotland
    I am not an expert on this but you should be able to find some answers in the Tech Talk forum
    Computer hardware & Home Cinema PCs (HCPC)
    I have read that it is a good idea to have your refresh rate and frame rate linked. If you NTSC DVD movies a lot use 72Hz (3x24Hz) or PAL use 75Hz (3x25Hz). Not sure about standard 30fps US stuff.
    Brian
  3. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    I think the X-Card outputs at native NTSC or PAL refresh rates, thus 60 and 50 Hz.
    If you get a Hush with the new M10,000 motherboard it will be fine for using without an X-Card to your projector. If you get a copy of TheaterTek v1.5 that will do the job fine.
    If you set the normal PC output to the native resolution of projector then that will give the best results.
