Progressive Scan on VGA
Discussion in 'Blu-ray & DVD Players & Recorders' started by olli, Apr 7, 2003.
  1. olli
    olli
    Interested in a player that can output PS on VGA rather than component.
    AFAIK there is only one model - Philips DVDR1000MKII that has PS output on VGA. Are there any players that can do the job?
    Alternatively is there a cost effective solution to take the PS feed from component to VGA input of my projector?
    Olli
  2. hazard
    hazard
    Apr 24, 2002
    137
    Cork
    +3
    Check out the Primare V25. See www.primaresystems.com
    There is at least one happy owner on this forum, try a search.
  3. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
  4. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    Yeah I'd also recommend a Primare V25. You can get the firmware upgrade for PAL progressive for it yourself from http://www.whatvideotv.com , unless you buy it already modified.
  5. jmack
    jmack
    i`m not sure what quality your after but i bought a dvd player with progressive out on vga from www.aria.co.uk on my plasma the picture was not great but it was only £70
    hope this helps
  6. olli
    olli
    Thanks for the replies.
    Either it is a bit expensive (transcoder connector around £350 or Primare player around £1000) or it is really a low budget (£88 for Aria player - correspondingly poor display properties). Guess I will have to wait a bit long to see if something in the mid-range shows up.
    Thanks again.
    -Olli
  7. Lare
    Lare
    Skyworth and Nintaus are Asian brands which feature VGA output and some models have Faroudja's DCDI which is very good deinterlacer.
    And this is real RGBHV "VGA" output, not some converted component->VGA.
  8. olli
    olli
    Skyworth 1050p (vga model) is out of stock. There is one UK dealer - laservision.co.uk who has a basic skyworth model which won't do, but he offers vga prog scan through an unknown chinese make called Kebao PD VD-KB2089. Any knowledge on Laservision or Kebao?
    -Olli
