Progressive scan on Tosh PF2 question
Discussion in 'Projectors, Screens & Video Processors' started by bboy-mass, Oct 11, 2003.
  1. bboy-mass
    bboy-mass
    Dec 31, 2002
    338
    Birmingham
    +12
    Hi ,
    I have a Toshiba PF2 TV and I want some answers to the following questions:
    1. Is the ProgScan built into the TV or is it only going to work with a ProgScan DVD player ?.
    2. If it is built in, does that mean my xbox,vcv,laser disk with also be ProgScan when connected to the TV?
    I have just connected a iSCAN to the TV and the DVD playback looked the same to me????.
    P.
  2. chuwright
    chuwright
    Oct 26, 2003
    96
    London
    +5
    You will need a progressive scan DVD player, any game you use on the Xbox must also support progressive scan.
    Regards
    Michael
  3. gmt steve
    gmt steve
    Aug 19, 2002
    648
    Manchester
    +6
    I disagree with the above statement. I have a Toshiba Strata, which apart from PAL prog is very similar.
    The TV has it's own line doubler built in. If you connect a prog scan DVD via the component input, then the internal doubler is bypassed, but any other source can be displayed progressively, albiet at a lower quality. The internal doubler also does not have 3:2 pulldown, so none progressive NTSC signals are very ropey with loads of combing artifacts.
    I don't understand how you connected an i Scan though, I thought that they only output via VGA.
