Progressive Scan on the Toshiba SD900
Discussion in 'Blu-ray & DVD Players & Recorders' started by Giblets, May 14, 2002.
  1. Giblets
    Giblets
    Is it possible to disable the progressive scanning?
    I need to use the component output to my Iscan box. The Iscan box doesn't like a progressive input. I don't want to bypass the Iscan.
  2. JSW
    JSW
    Feb 21, 2002
    4,283
    Staffs
    +333
    yes you can choose the output mode in the setup menu.
  3. Giblets
    Giblets
    Ok, Perhaps I'm being a bit slow, but I can't see how.... Which menu option is it under?
  4. JSW
    JSW
    Feb 21, 2002
    4,283
    Staffs
    +333
    Sorry maybe not, just been looking in the manual but dont help much does it :(
  5. Guest
    There's a button on the remote to toggle between interlaced and progressive, you have to be in stop mode to use it btw (i.e. not playing a disc). It's one of the buttons under the flap btw..
    Andy
  6. Giblets
    Giblets
    Got it! Thanks Andy.
