progressive scan on the sony 1272qm
Discussion in 'Projectors, Screens & Video Processors' started by pj, Aug 1, 2002.
  1. yes, it was an improvement
    2 vote(s)
    100.0%
  2. yes, not much of an improvement
    0 vote(s)
    0.0%
  3. i wouldnt bother!
    0 vote(s)
    0.0%
  4. no
    0 vote(s)
    0.0%
Thread Status:
Not open for further replies.
  1. pj
    pj
    Mar 15, 2002
    2,448
    117
    w.mids
    +521
    i assume the only way to do this would be through the rgb input(5 bnc's) just wondering how to go about it! i can get a prog scan player with component out (3 rca) but how can i connect this to the PJ? i can also get a prog scan player with a VGA out on the rear would this be a better solution? has anyone tried it? as i dont fancy forking out for prog scan to find it wont work with the 1272! also any cheap prog scan player preferences (dont laugh, but im on a £250 budget!)
    thanks
    PJ:confused:
  2. bxd
    bxd
    Oct 17, 2001
    1,487
    Southampton
    +134
    There are a couple of dvd players with vga (rgb h&v sync) progressive outputs. Do a search on the Skyworth and the Nintaus (spelling ?) dvd players. I use a Skyworth player on an electrohome projector and it works very well
    You may also find that one of these cheap players with progressive pal outputs (Debenhams have one... can't remember the name) from it's scart socket would be suitable but you may also need a sync booster (from Keene) to give you a signal that your pj can sync up to.
    You can go the component route but you'll need a Key Digital component to rgb converter to do the job. That will cost a couple of hundred dollars.
    Brian
  3. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    Bit of a strange poll for a PJ that won't take component in.
  4. pj
    pj
    Mar 15, 2002
    2,448
    117
    w.mids
    +521
    the nintaus is the foremost in my mind too! just gotta find one!
    Roland Brooks ~ B4 Projection Ltd
    will it do progressive throught the rgb input i was told it would? there is a component add on board or something but if i can do it through vga i prefer that!
  5. Gordon @ Convergent AV
    Jul 13, 2000
    14,218
    +3,073
    The 1272 when set up well should be running about 600 lines on a 16:9 screen when doing an anamorphic squeeze. It'll look great when fed an rgbhv 480P or 576P signal. I have a customer who runs his 1270 at 1200P!!!!!!! SOLELY for playing online games.....
    Good luck trying to find a de-interlacer. Also don;t assume that all de-interlacers are the same. A crap doubler/de-interlacer will create more artifacts and soften the image to a level where it may look much worse than the direct feed from the source...
    Gordon
Thread Status:
