Progressive scan on Panasonic E95
Discussion in 'Blu-ray & DVD Players & Recorders' started by Nelviticus, Aug 26, 2004.
  1. Nelviticus
    Nelviticus
    Jun 21, 2003
    473
    Hitchin
    +69
    I have a cable box that sends an RGB signal via SCART to my Panasonic DMRE95, which at the moment sends an RGB signal via SCART to my TV. Seeing as my TV supports component video and progressive scan, I could ditch one of the SCARTs and hook the Panny up to the TV using component cables.
    That would give me the best DVD playback possible, but what would it do to the signal from the cable box? Does it de-interlace it so that it becomes progressive scan? This is an important question because the TV has to be manually set to prog scan mode, so if the Panny doesn't de-interlace it I'd have to manually change settings whenever I changed between DVD and cable playback.
    Just wondered!
    Nelviticus
  2. Siamese Cat
    Siamese Cat
    May 31, 2004
    619
    46
    London
    +137
    Nelvitecus...I'm pretty sure it does turn the interlaced signal into progressive but why don't you try it and tell us? I'd be very curious to hear if it improves the picture fom Sky significantly
  3. lloydo
    lloydo
    Mar 1, 2002
    75
    Letchworth
    Bit confused here are we only talking about a recorded program from SKY being played back or are we talking about live SKY being passed through the E95 which will be prog scanned??
  4. cdb
    cdb
    Mar 1, 2003
    475
    28
    +47
    Nelvitecus, what did you find out?
    I've just got a similar set up and I find that I can't have rgb and compontent together. If I use the components out, I lose the use of rgb on the av1 input and messing about manually seems to be the only option :mad:
