Progressive scan on DV79?
Discussion in 'Arcam Owners' Forum' started by Geoffrey, Nov 23, 2004.
Tags:
  1. Geoffrey
    Geoffrey
    Jan 27, 2003
    42
    When playing DVDs, is the output from a DV79 always in progressive scan? If so, can it be changed to allow another unit to do the same job?
    Thanks,
    Geoffrey
  2. John Dawson
    John Dawson
    Jan 16, 2001
    852
    43
    Cambridge, UK
    +112
    You can choose to output interlaced or progressive scan from the on-screen set up menu, on both component video and HDMI. The only caveat is that both must be the same, i.e. the player cannot simultaneously support interlaced from some outputs and progressive from others. Composite and s-video will be disabled if you choose progressive scan.
    Hope this helps,
    John Dawson (Arcam)
  3. Geoffrey
    Geoffrey
    Jan 27, 2003
    42
    Dear John,
    How very kind of you to reply, especially after the events of the last few days!. I will go down now and look at the menu..
    Thanks again
    Geoffrey
