Progressive Scan on DV27A
Discussion in 'Arcam Owners' Forum' started by mutley, Jun 14, 2005.
Tags:
  1. mutley
    mutley
    Jul 28, 2002
    450
    Portugal
    I've had my projector for repair so in the meantime i had to turn my player to RGB through SCART to watch movies on TV.
    Now the projector is back, i changed the output to Component but the Progressive scan option on the menu says "not applicable" and doesn't let me go there and change...
    So the player must be sending interlaced signal to the projector. Before it was set to progressive and i'm sure i've changed that option before...
    How to solve this? :lease:
  2. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    I think you'll find there are two sets of component outputs on the back of your DV27A, one ouputs interlaced and the other outputs progressive. The reason why it says 'not applicable' in the menu is because both outputs operate simultaneously and are always on.
  3. mutley
    mutley
    Jul 28, 2002
    450
    Portugal
    Ok so the progressive output operates automatically just by conecting in the right output (that's where i conncet it) ?
    If so it's just me making confusion cause i thought i had changed that in the menu.
    Thanks!!!!
  4. steeled
    steeled
    Apr 23, 2002
    485
    28
    Maidenhead
    +54
    The Progressive Scan outputs are in a line at the top of the backpanel on what appears to be (and is) an expansion card. The component outputs that are amongs the other connectors and are in an L-shape are the interlaced outputs.
    If you have switched to RGB for the SCART output then the interlaced outputs will have RGB on them also.
    HTH
    Dave
