Progressive scan on a TV
Discussion in 'General TV Discussions Forum' started by jayjay, Jul 23, 2003.
  1. jayjay
    jayjay
    Jul 18, 2001
    352
    nwsex
    +7
    Hi folks - apologies if this is a dumb question.
    What exactly does it mean if a TV is progressive scan capable. Does it actually make a difference? I understand how it works with a projector but what about a TV - I thought that a TV was an interlaced device. Or am I just getting completely mixed up?
    Dependent on an answer to my first question. Does it make sense to buy a PAL prog DVD player if you're using a TV?
    TIA
    Jay
  2. jayjay
    jayjay
    Jul 18, 2001
    352
    nwsex
    +7
    Anyone?
  3. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,242
    Manchester
    +749
    Normal TVs indeed use intelaced scanning .
    Your PC monitor normally uses progressive scanning (although many can also use interlaced modes too).
    Recently a few TV manufacturers have begun to produce TVs that have , in addition to normal interlced scan , progressive scan capability.
    There is a Progressive Scan section within these forums if you want to know more (in the Tech. secction).
    Chris Muriel, Manchester.
