progressive scan ntsc/pal
Discussion in 'TVs' started by miskin83, Jun 14, 2004.
  1. miskin83
    miskin83
    hi
    I will be purchasing a 32" widescreen tv very soon.
    I have been looking at the tosh32" picture frame and panasonic tx32pd30 but i have just seen the jvc hv32d40 32" which looks as good if not better the then tosh/panny.
    The only difference between the jvc and the tosh/panny is the JVC will only accept Component Input for PAL Progressive: Compatible with HD1080i (HD1125i) signal. What does this mean? I only play r2 PAL DVDS.
    can somebody help
    As anyone got the jvc tv, is it any good?
    thanks
    Anthony
  2. tutu
    tutu
    Apr 28, 2004
    2,217
    48
    +58
    A look on the net or IRL? ;)
    Please say you have seen the MIA JVC...
