I have a panny 32ph40
and as far as i know it supports pal, pal60, ntsc, pal prog and ntsc prog via component input AV4
I have my denon 2800mkII pal prog dvd player running through the component inputs and it plays progressive scan ok
My only problem is that I get about a 3" shift to the right on progressive scan input? If anyone has any info on solving this or why it happens I'd appreciate it?
Also with component input i get a green tinged vertical band in the middle of the screen, which is only visible when the screen goes completely black, so not a problem during most films. Any help with this would be most appreciated as well.
