Progressive Scan Modes on Xbox
Discussion in 'Xbox Forums' started by windfall, Sep 6, 2004.
  1. windfall
    windfall
    Oct 19, 2003
    2,410
    48
    LFC Kop End
    +62
    Hi All
    I have been running my xbox in 480p but I also switched on the 720p and 1080i modes.
    On my Panasonic AE100 I checked the input signal and it's showing 525p.
    According to my PJ manual it shows support for 720p and 1080i but I cant get the xbox to output these modes or I cant get the PJ to get these from the xbox.
    I tried connecting the xbox directly to the PJ and also via my amp(default usage) but neither will show a signal greater than 525p.
    Can anyone help with this?
    Tone
  2. sirp
    sirp
    Jan 20, 2002
    887
    28
    Derby
    +53
    depends on the game, only some support those modes
  3. azzo
    azzo
    Feb 13, 2002
    1,009
    38
    Wokingham
    +9
    480P is the best resolution for this PJ anyway, 720P and 1080i will require extra scaling so the picture wouldn't be as good.
    I presume you are using the hi-def cable and running a chipped x-box in NTSC. If so, then as sirp says, it depends on the game
    Azzo.
  4. windfall
    windfall
    Oct 19, 2003
    2,410
    48
    LFC Kop End
    +62
    Cheers for that chaps, Azzo yes your correct in your assumption.
    I am well happy with the (PJ says so) 525p pic its getting, just wondered if it could get better!
    Tone
