progressive scan making picture worse on my plasma, Why?
Discussion in 'Plasma TVs Forum' started by GalacticaActual, Sep 13, 2004.
  1. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,938
    Galactica C.I.C.
    +283
    Ok.
    MY dvd player is a pioneer dvd757ai. It is connected to my panasonic viera via componet input. The player will out put a progresive signal when playing back an NTSC disc. When I switch it to this mode I get more of the wild green pixel effect on screen than I do if I am using standard interlased and letting the plasma do the proccesing. In effect a feature on my player is actually making the picture on the plasma worse not better :confused: any Idears why this might be. Would a better set of leads help? Are the vieras not very good when actually reciving a progresive scan signal? Is it time to up grade the dvd player!! :D :D
    Any help guys would be apreciated.
    Cheers.
    Dave.
  2. ianh64
    ianh64
    Aug 7, 2004
    2,233
    SW London/Surrey borders
    +63
    If you have calibrated your set for interlaced, you will need to recalibrate for progressive input. Brightness would appear different between the two. Not sure if this will make the green effect disappear.
    -Ian
  3. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
    NTSC has a different black level to PAL
  4. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,938
    Galactica C.I.C.
    +283
    Thanks guys :thumbsup:
  5. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
    my philips dvdr75 has a setting to "restore NTSC black level"
    but no component output. All we need is a dvd player with both!
