Progressive scan - is it worth it
Discussion in 'Blu-ray & DVD Players & Recorders' started by gazza30, Sep 25, 2004.
  1. gazza30
    gazza30
    Should I be that bothered abut getting a DVD recorder with progressive scan output capability. Does it make that much of a difference in picture quality. Is it only useful for large (eg. 42 inch +) plasma displays or would I notice a difference on a 32/36 inch CRT TV with component/progressive compatibility. Also, this may be a dumb question but is progressive scan only compatible with pre-recorded DVD movies, or would I notice a difference with stuff I have recorded onto the HDD or DVD myself.
  2. lmccauley
    lmccauley
    Oct 24, 2000
    3,430
    Newcastle
    +268
    It depends how good the deinterlacer is in the display device compared to the deinterlacer in the DVD player. Do you have specific models in mind? If so, do you have the specs for the deinterlacers?
    Cheers,
    Liam
  3. Bob Todd
    Bob Todd
    Aug 20, 2000
    3,080
    UK
    +369
    you will notice the image wont flicker anywhere near as much
  4. gazza30
    gazza30
    I'm trying to decide which DVD recorder is best suited to my needs. I currently have a 4:3 28 inch Toshiba TV but I may be upgrading soon to a 32/36 inch model (possibly with component input) or even a plasma (if I can talk my wife into it). I tend not to buy/rent that many DVD movies, the recorder will mainly be used for watching stuff I have recorded off Sky TV. So I guess my real question is, would progressive scan be an improvement for watching SKY/broadcast recordings, or does it only come into play when watching pre-recorded DVDs.
  5. lmccauley
    lmccauley
    Oct 24, 2000
    3,430
    Newcastle
    +268
    Well, most plasmas display progressively (except for the Fujitsus with their ALIS panels), so the plasma will have a deinterlacer built-in. I have a Panasonic PWD6 and the de-interlacer isn't half bad. Whether the picture looked better with a progressive scan DVD player would depend on whether the DVD player does a better job of deinterlacing than the plasma.
    What you're doing is choosing between these two scenarios:
    DVD player ------interlaced----------> Plasma de-interlacer -> Plasma Panel
    DVD player -> DVD de-interlacer --------progressive---------> Plasma Panel
    either way, the picture displayed is progressive.
    Cheers,
    Liam
  6. THOWD FELLA
    THOWD FELLA
    I have a 36 inch toshiba that accepts component input with progressive scan and have just bought a pannasonic e65 recorder because it has this feature. However when I sat it up it says in the manual that progressive scan is not recommended with CRT televisions as you may well get flicker round the edge. If you do -turn progressive off but I have not had chance to try this yet, It says p.s. is for plasma and projectors only. Having said all that, component output of dvd's is fantastic.
  7. fuzzy
    fuzzy
    Sep 8, 2002
    40
    I have a panny tx32ph40 bought 2 yrs ago which despite its reviews have been pleased with when watching dvd's freeview etc. Just recently bought panny e85 recorder with prog scan and am seriously impressed when watching dvd's so I would say it is worth it and this is with a telly that was slated when it came out.
  8. gazza30
    gazza30
    So let me get this right, if I have a display (CRT or plasma) which has progressive capability, I don't need a DVD recorder that gives progressive output because the TV will do that for me. I was under the impression that you needed both progressive output from the DVD and a progressive compatible TV. If it's just a case of having one or the other then that will help me decide what I need to get. Also, back to one of my original questions, does progressive scan only make a difference on pre-recorded DVDs, or would I see an improvement on stuff I have recorded onto the HDD. People seem to have differing opinions on whether progressive scan makes that much difference at all.
  9. fuzzy
    fuzzy
    Sep 8, 2002
    40
    on my panny ph40 tv you can select progressive scan rather than 100hz but this results in a slight flicker if the source is not progressive. I still think it looks better though. With my dvd recorder connected via component cables and progressive output enabled on the dvd the flicker disappears and the picture has a very cinema like look to it. To answer your other question I think your telly if it s a CRT needs to be progressive compatible to accept a progressive input. With programmes you have recorded on the HDD I'm not entirely convinced that the progressive output is any better or any worse. hope this helps
  10. lmccauley
    lmccauley
    Oct 24, 2000
    3,430
    Newcastle
    +268
    You don't need a DVD player with progressive output if the display has progressive capability. But, you might want a DVD player with progressive output if the DVD player's de-interlacer is better than the display device's
    It's no good having a PS DVD player if the display device does not have PS inputs (almost always on component inputs - but not all component inputs support PS). But, you can get a progressive picture with a PS display device and a DVD player with only interlaced output (which is what I have) - with the caveat above.
    A decent deinterlacer should be able to reconstruct film-based material in the correct manner, whether it's from DVD or Sky, because it will analyze the picture to determine whether it needs to do 2:2 or 3:2 pulldown, rather than using the progressive flag on a DVD.
    Well, how much difference it makes is a subjective thing. The only way to decide is to arrange a demo and look for yourself.
    Cheers,
    Liam
  11. Wharfman3
    Wharfman3
    really newbie question- is progressive scan only available with componenet conections?
  12. F G Evans
    F G Evans
    I have a Tosh 42PW23 RPTV - it does not make its own progressive image. However if i connect a progressive DVD player will i get a progressive image ?
  13. steveho
    steveho
    Apr 21, 2004
    164
    +3
    panasonic 42pe30b + panasonic dmre-95
    i cannot see any difference between the component progressive connection and the rgb equipped scart connection
    steve
  14. lmccauley
    lmccauley
    Oct 24, 2000
    3,430
    Newcastle
    +268
    Yes (if you're talking analogue - digital HDMI connectors can also send a PS signal).
    No.
    If you want to learn more about progressive scan, you could do worse than read some of the posts in the Progressive Scan Forum. It took me a little while to get my head round it, but it's actually fairly straightforward.
    Hope this helps,
    Liam
  15. hornydragon
    hornydragon
    Dec 19, 2001
    28,310
    +1,217
    on most TV's yes also available on VGA for plasma and PJ use
