Progressive scan greyed out
Discussion in 'Plasma TVs Forum' started by Billythekid, Nov 1, 2005.
  1. Billythekid
    Billythekid
    Jul 11, 2005
    OK. After waiting since June, my TH42PV500 arrived yesterday. It's currently looking very fine on the wall. But...no progressive scan. I have decent quality component cables from a Panny DMREH50 into the component on the TV, but the image is black and white. The setup menu on the DVD recorder has "progressive" greyed out under connections. No amount or unplugging, reseating, rebooting etc. has any effect. Anybody think of anything obvious (or even obscure) that I may done wrong?
  2. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    some dvd players require RGB scart to be turned off before progressive can be enabled. either that or set it to YUV or Y, Pb, Pr or Y, Cb, Cr
  3. Baron Von Doom
    Baron Von Doom
    Mar 15, 2005
    1,569
    worthing
    +176
    go to connections then av1 output. change it to video(with component). you should then be able to switch on progressive
  4. Billythekid
    Billythekid
    Jul 11, 2005
    That's the one!
    I can't have "AV1 Output" set to RGB and have component output.
    Many thanks both.
