Progressive Scan Function
Discussion in 'LCD & LED LCD TVs Forum' started by jamezm, Mar 20, 2006.
Tags:
  1. jamezm
    jamezm
    Aug 18, 2005
    1,076
    48
    Fareham
    +34
    Sony DAVS-550 DVD player to Samsung LE26R41 via Component. The 'Progressive Scan' function is greyed out in the DVD player's menu, yet both the player and the TV are 'progressive scan' compatible. Any ideas? Am I missing something obvious...?
    I would really like to improve the picture which is currently fairly poor and pixellated, even via component, I am wondering whether this is due to the current interlaced output, and I am trying to set to progressive to improve.
    All constructive feedback welcome!
    Thanks in advance
  2. stevelup
    stevelup
    Aug 13, 2002
    6,793
    Swindon
    +1,293
    I'm not sure that the DAV-S550 DVD player can do PAL progressive. I think it's NTSC only.
    You could try a R1 DVD and see if that enables your progressive menu option.
    I'm not convinced it will make any difference though - it's the scaling rather than the deinterlacing which is probably giving you the pixelated look
    Steve
  3. russ123
    russ123
    Jul 31, 2004
    841
    46
    South Of The River
    +119
    I'm not sure on the DAVS-550 but on my parents sony dvd recorder there was a little swirtch at the back that toggled the output between scart and component.
