Progressive scan from DV27
Discussion in 'Arcam Owners' Forum' started by Tracey, Jun 1, 2004.
Tags:
  1. Tracey
    Tracey
    If I connect my DV27 direct to a plasma screen using a component lead, does that automatically output progressive scan component or would I need to change something in the menu?
  2. cwick
    cwick
    Feb 4, 2002
    2,231
    Reading
    +95
    There's two sets of component outputs on the DV27 - one interlaced, one progressive. So I'd assume there's nothing to change in the menus.
    Pretty sure you'll have to switch it into component if you're using the scart output though.
    Not much help really, am I :(
  3. Tracey
    Tracey
    Thanks. I changed it to component rather than RGB on the DV27 menu as I was using the scart connection before, to be honest I just wanted to watch my new plasma so I plugged it in and it worked so I left it at that. I think I need to read the manual tonight to check I'm using the right outputs.
  4. cwick
    cwick
    Feb 4, 2002
    2,231
    Reading
    +95
  5. Tracey
    Tracey
    Thanks for that, I had a look last night and yes it was plugged into the wrong one (only a 50/50 chance of getting it right). I'm not sure I can notice any difference though, it's a great picture either way.
  6. BigAl217
    BigAl217
    Apr 4, 2004
    225
    +18
    Wish my plasma accepted Pal Progressive :( :( :(
