Progressive Scan from a Arcam DV27
Discussion in 'Blu-ray & DVD Players & Recorders' started by Hawklan, Feb 28, 2002.
Tags:
  1. Hawklan
    Hawklan
    Oct 20, 2001
    6,786
    Essex
    +322
    I've just purchased a Arcam DV27 and now want to upgrade my TV to accept progressive scan input
    This is where I am stuck
    What do I need in the way of a TV
    Just to let you know I'm not interested in a Plasma Screen (Price)
    or using a front projection screen (convience)
    Can somebody recomend the route I should take and makes / models that I should demo
    RON
  2. lmccauley
    lmccauley
    Oct 24, 2000
    3,563
    Newcastle
    +345
    There is currently only 1 TV available in the UK that accepts a Progressive Scan input - the Loewe Aconda with VGA board. There have been several posts going into great detail on how to get this to work, so I would suggest you do a search for them.
    Good luck!
    Cheers,
    Liam
  3. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    Unfortunately I don't think you will be able to interface you Arcam with you Loewe!:(
  4. Lowrider
    Lowrider
    Unless you buy a component to VGA converter, and then the TV still wont accept PAL progressive... Guess you have to wait a little longer...
  5. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    and the component to VGA adaptor introduces it's own degredations to the signal!
