Progressive scan DVD?
Discussion in 'Projectors, Screens & Video Processors' started by blueferre, Mar 25, 2001.
  1. blueferre
    blueferre
    Should i buy a progressive scan DVD player (pioneer 737)for my new tv Hitachi (C43WP910TN progressive scan),or should i keep my Hitachi DV-P505E.Will a Progressive DVD player make any difference?
  2. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,658
    7
    167
    Birmingham, UK
    +10,544
    For a start, does the TV have inputs compatible with the player you propose to buy?
  3. blueferre
    blueferre
    What kind of inputs do i need? What about scart input,or do i need Component input?Am Confused!
  4. Ace007
    Ace007
    Hi blueferre,
    ProScan is only feed through Component Out.
    Here's a Pic of the back of the Pioneer737
    [picture deleted by Spectre - naughty to link to images like that - particularly huge ones].
    As far as improvements are concerned, From what I have hears you should see a dramatic improvementwhen using ProScan. But bear in mind you will only be able to apply ProScan on NTSC material with the Pioneer737
    Hope that helps,
    Ace
    [This message has been edited by Ace007 (edited 26-03-2001).]
    [ 22-06-2001: Message edited by: Spectre ]
