Progressive scan dvd to a RP TV with component inputs
Discussion in 'General TV Discussions Forum' started by raigraphixs, Nov 12, 2001.
  1. raigraphixs
    raigraphixs
    Jul 11, 2001
    60,434
    +22,068
    1. Is anyone currenty using a tosh 900E dvd player (progressive scan player) with an Tosh RP set, using Progessive scan R1 dvds, via the component inputs?.
    I have a list of questions on the 'dvd' players section that involves TV, can anyone share their knowledge with me and correct me if i am wrong. As i am not sure the answers i have got are quite right?
    link
    http://www.avforums.com/frame.html?...ms/showthread.php?s=&postid=144649#post144649
    if the above link does not work, look for 'Progressive scan dvd player and tosh rp set' heading or simliar by me.
    thanks
    rai
  2. CarlB
    CarlB
    Jan 8, 2001
    1,303
    Cambridgeshire
    +227
    The answers you receicved in the other thread are correct. The 40WHO8B does not display pro-scan images. I currently use an SD9000 conected via component to my 40WHO8B, and have tested the SD900 on the same set but could not see enough of a difference to justify upgrading.
    As mentioned, I believe the Loewe set is the only one to display pro-scan in the UK at the moment, else you need to look at Plasmas and pro-scan projectors.
  3. raigraphixs
    raigraphixs
    Jul 11, 2001
    60,434
    +22,068
    What are your impressions of your SD9000 dvd player connected via components.
    Currently i still have tosh 2109b connected via s-hvs.
    I am looking for a new player for my 40who8b.
    rai
