Progressive Scan DVD Players
Discussion in 'Blu-ray & DVD Players & Recorders' started by mistermcgee, Nov 4, 2003.
  1. mistermcgee
    mistermcgee
    Hi All
    Could I pls be informed about my question here.
    I'm thinking to buy a DVD player with progressive scan, but it's hard to find som concrete information why i should.
    Can any of you pls advise me in why progressive scan is good ? Is it good on 50Hz tv compared to 100Hz ?
    And what output device is best to use if you want to get the most out of progressive scan (component, S-VHS, Composite) ?
    Thanks in advance.
    MisterMcgee
  2. slingshot
    slingshot
    Jan 31, 2001
    1,212
    48
    UK
    +32
    Have a look at www.progressivescan.co.uk
    You will only get progressive scan out of component outputs, so you don't have any choice of connection.
    Hope that helps a bit.
    Slingshot
