progressive scan dvd on pw5
Discussion in 'Plasma TVs Forum' started by ted26, May 12, 2003.
  1. ted26
    ted26
    Apr 10, 2003
    512
    yorkshire
    +6
    After reading several articles on dvd players i am thinking of buying a progressive scan dvd player!
    I own a panasonic 42" pw5 and would like to know if this plasma accepts such a signal?
    any help on this matter much apreciated as my head is starting to hurt
    :confused:
  2. JamesTapp
    JamesTapp
    Oct 2, 2002
    235
    16
    Bedfordshire
    Yes it supports both 576P (PAL Progressive) and 480P (NTSC Progressive).
  3. sharkbait
    sharkbait
    Yup ... I have the same plasma panel and have a Limit 9900 DVD player connected to it which produces PAL progressive.
    I have to say, I am unconvinced between progressive and interlaced with this setup. There is not a huge (if any) difference. It may be that the plasma does such a good job of displaying an interlaced signal that you could get a better DVD player that does not do progressive scan.
    I'm sure there are lots of other people on here who can explain the theory behind this ... I am purely talking from experience of the kit I have. I may be wrong.
  4. nathan_silly
    nathan_silly
    Cheap player. You've got a 4K panel and using a 200 quid player... replace the Limit with something like a Pioneer 757ai or better.
  5. sharkbait
    sharkbait
    You're not the first person to suggest that Nathan ... do you reckon it will make that big a difference?
  6. nathan_silly
    nathan_silly
    YES :)
    Well you did say big :D
  7. ted26
    ted26
    Apr 10, 2003
    512
    yorkshire
    +6
    Is there any need to shout :nono:
    but back to the subject, can u recomend a dvd player that does pal progressive not just ntsc?
  8. JamesTapp
    JamesTapp
    Oct 2, 2002
    235
    16
    Bedfordshire
    Sharkbait,
    Many people are happy with the Limit, don't be influenced to upgrade for the sake of it. If you do consider the upgrade get a trial at home - your local dealer should do this for you, and if you do see a big difference - then fine...
    When Nathan has a TV that can support PS maybe then he would be better placed giving advice on it. :boring:
    BTW, if you do the demo, buy from that dealer - even if it costs a few quid extra than a net purchase, it is the only way these guys are going to carry on offering this kind of service.
    BTW, my DVD cost me £150. Sony DVP-NS900. Doesn't have to be £800 or more just 'cause you have a plasma.
    Good luck,
    James
  9. nathan_silly
    nathan_silly
    Ok stick with your cheapo players then. :rolleyes:
    I guess you think there's no difference between a £100 Samsung and £1600 Onkyo then?
  10. Nike
    Nike
    Feb 27, 2001
    667
    bournemouth, UK.
    +20
    I'm currently getting very good results using the limit with a Panasonic panel.
    I notice a massive difference between interlaced/progressive especially on PAL. I think the panel was already doing an OK job de-interlacing NTSC material - it's still better though with a PS feed.
    I probably will get another player - when there are some others to choose from.
  11. sharkbait
    sharkbait
    Nike, do you see a big difference between progressive and interlaced. That's interesting, cos I'm not.
    I'm using the Limit with a Panny 42" series 5. Hmmm ... might have to have a play with it a bit tonight and see if I'm missing something.
    We use the panel primarily for watching Sky (it's in the bedroom), so I didn't want to pay a lot for a second DVD player - the Limit is nice for the money.
    Thanks for the feedback.
  12. Luc
    Luc
    Aug 7, 2000
    420
    I've got a Harmon/Kardon DVD25 which is Pal prog hacked, and i have to say that the progressive image on my Panansonic 5 series is definately better than the interlaced one. I can't quite put my finger on why it is, but it was definately worth the upgrade.
  13. mw3cdj
    mw3cdj
    Nov 12, 2002
    399
    West Wales
    I've got a hit pma400e display and a sony dvd725 . A kind dealer loaned me a h/k dvd25 to try progressive scan on the pma400e , and after 4 days of playing with all sorts of settings i took the h/k dvd back. From what i could see my sony dvd725 gave a sharper and clearer picture with no artifacts that i can see .Also a lot more screen noise on th h/k.
  14. symanski
    symanski
    Jun 20, 2002
    874
    Scotland
    +8
    I'll second that! There's lots of people, even on line retailers, that are offering extra advice. They do take time to describe the best way to connect up your system, and that quite frankly has to be paid for. If we don't support these poeple we'll end up with only Dix-urry-werhous-omet places where they still believe that you've got to refill your plasma with gas every year!
    All the best,
    Dr John Sim.
