progressive scan dvd for PTAE100
Discussion in 'Blu-ray & DVD Players & Recorders' started by kim@cheung1957., Apr 8, 2003.
  1. kim@cheung1957.
    kim@cheung1957.
    What best deal prog. scan dvd player for the PTAE100? Thanks!!!
  2. gothmog
    gothmog
    Dec 17, 2002
    204
    16
    Sunny Shipley
    The biggest bargain has to be the Limit from Richer Sounds.
    PAL/NTSC progressive and DVD-A for £150 :D
    -- Jon
  3. Kramer
    Kramer
    Moved to more appropriate forum.
  4. kim@cheung1957.
    kim@cheung1957.
    Thank you for your help. The price is too good to be believed. May i ask where can i get a review of the Limit. Does it the quality trustworthy!. Once more, someone recommend the Toshiba SD520. Anyone gets me some ideas? Thaqnks again.
  5. fraggle
    fraggle
    Dec 11, 2002
    1,441
    Milton Keynes
    +29
    People have noted that the Limit is a cheap player, and it shows. The internals are fine, but the drive door has been known to fall off, IMHO it feels cheap when you use it (rough edges on alloy buttons).
    Consider Philips 963sa (£308). (PAL & NTSC prog scan, SACD)
    Tosh 520 only does NTSC progressive scan.
    There's another player that I forget that does PAL and NTSC prog scan at about £400, anyone?
  6. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,436
    Surrey. UK.
    +2,097
    Harmon Kardon DVD25 is around £300 now and does PAL and NTSC prog-scan. I've not seen it though.
    The Toshiba SD520e gives a better picture than the Limit, but as has already been said, only does NTSC prog-scan. I wouldn't recommend the Philips 963 until the issues are sorted - the SD520 gives a better picture imho anyway.
    HTH
    Gary.
  7. kim@cheung1957.
    kim@cheung1957.
    Thanks guys!! It seems to be the best is heading for the H/K DVD25. One more question- my existing dvd player is Pioneer 626D with the Yahama 630 model, does the replacement for the H/K dvd 25 gives a great improvement with the ptae100. Or any other suggestions? My budget is under £400. Thanks.
  8. jhjerpe
    jhjerpe
    Mar 1, 2003
    696
    2
    28
    North London
    +63
    I've had the DVD25 demoed on the PTAE100 using the Component connections when I was deciding between projector / plasma and I was very impressed with the results. I've now got the DVD25 with my Plasma and am very happy with it! :)
  9. dean randle
    dean randle
    Jan 9, 2003
    154
    UK (Bromley)
    +6
  10. Lare
    Lare
    do note that HK25 doesn't have a good deinterlacer as Faroudja is. The Philips 963 does have a new Faroudja chip and also some Skyworth's models have it.
    Faroudja DCDI benefits when the progressive flags are not perfectly made, and this is often the case. Also several other technical issues (like combing in example) are handled by the deinterlacers, and the results differ.
    I liked this article:
    http://www.avsforum.com/avs-vb/showthread.php?s=&threadid=242002
  11. Andyclockwise
    Andyclockwise
    Apr 6, 2003
    128
    Leicester
    +13
    I have today bought a Limit 9900SE from Richer Sounds playing Proscan through my PTAE100 and the results are excellent. Thanks to this posting for alerting me to the Limit. An excellent machine for the money.
  12. kim@cheung1957.
    kim@cheung1957.
    nice to hear that the Limit 9900SE gives a good result on ptae100. How about the audio section, does it sound s well. One more wants to know, now i am using svhs cable for my ptae100 . To get the progressive result, does component cable must use for it? Thanks.
  13. Andyclockwise
    Andyclockwise
    Apr 6, 2003
    128
    Leicester
    +13
    Yes you will need component cable for progressive scan. Its not cheap - but I got a good price from Sound and Vision in Bolton £69 for 5m of gold plated plugs etc. You can pay a lot more but I suspect the law of diminishing returns starts to bite heavily once you get over a certain price level.
  14. Andyclockwise
    Andyclockwise
    Apr 6, 2003
    128
    Leicester
    +13
    Sorry, forgot to answer about the audio. It sounds fine to me - I am playing it through a Naim Nait 2 amp into Royd Eden speakers and they are quite revealing. I watched David Gilmour in concert DVD last night and I was blown away by the sound and picture quality - the picture is astounding, as good as the picture on a TV except several times bigger.
  15. evans
    evans
    Nov 24, 2002
    1,161
    48
    +36
    Ive got the asian philips Q50 and it has a very good picture with reasonable price does ntsc and pal progressive. On my 32 inch dist tv from jvc it has a cinema like picture that really strikes you.
    not bad for the price I paid. very happy with it. although now the 963sa is suppose to have slightly better picture due to the chip of faroudja.
  16. Jonny1973
    Jonny1973
    I'm also in the same boat.
    I'm considering the Limit 9900, Toshiba 520, Harman Kardon 25 but not the Philips 963.
    I had a 963 for a week and returned it. The picture was poor.
    Do any of the above players have 3:2 pulldown detection???
    I'd like PAL and NTSC Prog Scan but I mainly own NTSC discs.
    I see Tosh are launching a new range of players, what will the Tosh 520 be replaced by????
  17. kim@cheung1957.
    kim@cheung1957.
    Thanks! Ready to go for this low budget Limit9900. If the picture and sound works better than my Pioneer 626, i will put it as the main source for dvds. Ah!! Where does this product Limit comes from.... China, Asia or Europe.... Pl tell.
  18. Andyclockwise
    Andyclockwise
    Apr 6, 2003
    128
    Leicester
    +13
    According to the man in Richer Sounds they come from Belgium.
  19. bonzobanana
    bonzobanana
    Aug 21, 2001
    3,446
    Yeovil
    +219
    Its a route of hassle but you could get an xbox. Their about £130 now rrp so discounted probably £120 if you look hard enough. A cheapmod is about £12 all in and a component cable from dvdbox office in canada is less than £20 delivered. This also includes high quality component cables (gold plated). Then various downloadable software apps installed to the hard drive will give you progressive scan as well as divx playback and a mass of other formats including a few games ;-). You don't need the dvd remote dongle for this. I'm sure updated software will come along that will enable more features and options.
    However the best option for the PTAE100 would be a basic pc made up from various components. Probably cost in the region of £250 though but would give by far the best results and versatility.
  20. Andyclockwise
    Andyclockwise
    Apr 6, 2003
    128
    Leicester
    +13
    Interesting bonzo, as someone who has built a few home PCs this appeals. Do you have any suggestions as to the best place to find out more information on what components to use. I tried searching PC in this forum but its too short a word.
  21. magking
    magking
    Jan 6, 2001
    378
    Norway
    Search for "hcpc"
    And there is a forum for it here.
  22. calscot
    calscot
    Oct 29, 2002
    659
    16
    Milton Keynes
    No-one seems to have mentioned the Marantz DV4300 which does pal prog out of the box for about £229. I'm pretty interested in this one as it's very slimline and so should fit on top of my dvd recorder in my AV unit, but no-one seems to have reviewed it.
    Cheers,
    Cal.
  23. calscot
    calscot
    Oct 29, 2002
    659
    16
    Milton Keynes
    The X-box solution sounds very interesting. Does it have remote control? What's the picture and sound like? I take it it does DD5.1?
    Cheers,
    Cal.
