Progressive scan connection
Discussion in 'Projectors, Screens & Video Processors' started by Rikkibo, Jul 16, 2003.
  1. Rikkibo
    Rikkibo
    I am trying to connect a limit dvd 9900se dvd player to a panasonic TX32PB50 widescreen tv. The tv has scart and s-video inputs, but the dvd player does not work on progressive scan on scart. There are connections on the back of the dvd labelled Y, Pb/Cb and Pr/Cr. Can anyone advise me how to connect the two together. Thanks, Rikkibo.
  2. museumsteve
    museumsteve
    Jan 28, 2001
    7,919
    4
    Nth Hampshire
    +1,070
    as far as I know that TV doesn;t do progressive and doesn;t have component inputs, therefore you cannot get progressive from the player on that TV.:(
  3. museumsteve
    museumsteve
    Jan 28, 2001
    7,919
    4
    Nth Hampshire
    +1,070
    oh..and welcome to the forums mate :)
  4. Rikkibo
    Rikkibo
    That`s annoying to say the least. Is progressive scan only available on component inputs? There is an option on the scan mode setup as progressive, but if it won`t work from scart or s-vhs there`s not a lot i can do. Thanks for your time bud.
  5. bxd
    bxd
    Oct 17, 2001
    1,487
    Southampton
    +134
    You seem to have got caught up in the marketing hype over progressive scan. It's all a bit 'naughty' as there are only a few regular tv's that can handle a progressive signal at the moment. Progressive is better for large scale displays (projectors and 40+in plasmas) so I wouldn't worry about not having it on your particular set.
    With a few exceptions, progressive scan is usually (only) available on component video connectors. However, the display device needs to be capable of handling a progressive signal as well as having component inputs. Some tv's have component inputs but they are NOT able to handle a progressive signal. Many tvs do not have component inputs.
    The best picture on your tv is probably via a rgb signal to the scart connector.
    Brian
  6. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    See if your dealer would take your TV as part exchange for the PAL and NTSC progressive scan capable TX-32PD30.
    Steve
