Progressive scan conections
Discussion in 'Projectors, Screens & Video Processors' started by lolg, Mar 4, 2003.
  1. lolg
    lolg
    I want to know if it is possible to connect component out to a scart that accepts RGB input. I'm using Arianet2255 DVD player into Philips 32" Wide Screen.
    Can anybody help:)
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,174
    +3,004
    Component output YPrPb is not the same as RGB. So I would suggest not.......Not only that I do not know of any TV's that accept a progressive signal in on their Scart sockets
    Gordon
  3. Bada Bing
    Bada Bing
    Aug 8, 2001
    530
    Scotland
    +5
    lolg,
    If you find anything out about this let me know. I need to see if my Samsung PS-42P2ST accepts prog scan via the scart as it has no component inputs.
  4. dejongj
    dejongj
    We bought three of them for a work project. I was surprised to see no component inputs. It looks like the only way to get progressive scan is through the VGA input...So not much good with a normal consumer DVD player. You may have to go the HTPC route...
    Be carefull with them though as I already have screen burn on two and they are only 3 weeks old....
    Cheers,
    Jean-Paul
  5. Bada Bing
    Bada Bing
    Aug 8, 2001
    530
    Scotland
    +5
    They're crap, I now have an LG 17. Mine had screenburn before I even powered it up!
