Progressive scan and recorded TV images
Discussion in 'Projectors, Screens & Video Processors' started by djnsh, Oct 30, 2003.
  1. djnsh
    djnsh
    Most of the discussion in this section has understandably centered around progressive display of movies which are naturally non-interlaced, however what do the results look like when a DVD player plays a DVD containing TV recordings which are naturally interlaced.
    When I replay discs on a PC which obviously has to display DVD's progressively due to the nature of a PC display, movies on the whole look fine however TV recordings seem to have jagged edges on any fast movement such as football matches or quick camera pans.
    I am interested to see if a similar effect is seen with a progressive DVD player and projector set up, for example, which obviously is a backwards step if such visual artefacts are present.
  2. They
    They
    Sep 10, 2002
    171
    16
    Bristol
    De-interlacing originally interlaced video is a complex task if high quality is to be achieved. There are many methods, some simple ones used by most PC graphics processors and software DVD players but more sophisticated motion adaptive de-interlacers are beginning to appear in the latest graphics chips.
    Most PC de-interlacers for TV and DVD will use line averaging (bob) or field interleaving (weave) to create progressive frames. The former gives low vertical detail and jaggies and the latter can cause annoying serrations during motion.
    More sophisticated motion adaptive de-interlacers are generally used in stand alone DVD players and ,again, generally, produce good to excellent results.
  3. calscot
    calscot
    Oct 29, 2002
    665
    16
    Milton Keynes
    None of the software players do motion adaptive deinterlacing needed for video material.
    DScaler does this but as far as I know it only does it from a the signal from a video capture card so I don't know if or how you can connect a software DVD player to DScaler directly.
