Progressive question
Discussion in 'Blu-ray & DVD Players & Recorders' started by sefton, Oct 24, 2004.
  1. sefton
    sefton
    If I buy a dvd recorder with progressive output will any signal ie normal tv be made progressive or does it just apply to disks?
    I have freeview and was wondering if I could use the progressive output from a dvd player to increase the quality.
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,855
    Warwick
    +2,773
    Yes you can use progressive scan capable DVD recorders (Toshiba, Panasonic, JVC) to output any source progressively.
  3. sefton
    sefton
    Fantastic :thumbsup:
    Are there any differences in the quality of progressive scan or are they all the same?
  4. PHOBIC ®
    PHOBIC ®
    Oct 19, 2004
    198
    UK
    Hmm..interesting. I'd heard that to make use of Prog scan DVD recorders like my XS32, i would need a TV with Prog scan capability.
    Nice to know !
  5. Jever
    Jever
    Your device must have Prog scan capability, not alot of ordinary TV´s support progressive scan yet.
    But LCD/PLASMA televisions support progressive scan.
  6. albany
    albany
    Oct 20, 2003
    30
    So you are saying that you could hook up a cable box to the DVD via Scart and then output via component to a progressive capable monitor?
    Great if you can, but I thought the video signal was different. Interlaced or de-interlaced, summat like that, don't ask me I'm new to all this.
  7. Rasczak
    Rasczak
    Apr 3, 2002
    21,855
    Warwick
    +2,773
    You do - your TV has to be progressive scan compatiible to use a progressive scan output.
    Yes - the recorder acts as a converter. It (obviously) has to be 'on' for this to work.
  8. PHOBIC ®
    PHOBIC ®
    Oct 19, 2004
    198
    UK
    Thanks Ras - i almost thought then for second that i was going to get away with upgrading my ageing Hitachi TV
