Progressive Output from Pioneer 868
NeilH
I can't seem to get the player (aquired yesterday) to output anything other than an interlaced picture.
I have checked the settings numerous times and they seem to be OK. Whenever the output is et to progressive, the projector displays rubbish until I set the DVD player back to Interlaced mode. I'm fairly convinced that I'm doing something daft here and would appreciate any advice.
Neil.:confused:
Loada
I'm sure you've covered these but I'll mention them anyway!
1. Make sure you're using component cables ;)
2. Check the projector settings (as well as the player) are for progressive.
gmt steve
Also, when it's set to prog scan, the 868 has a small red light on the front panel confirming this. It's between the iLink and the Pure Audio indicators. So if this is lit then you know the problem lies further down the chain.
Paramount + UK launch: Halo, Star Trek and Beavis, and all the latest 4K + Movie/TV News
