Progressive Help!
Discussion in 'Blu-ray & DVD Players & Recorders' started by noyce, Aug 14, 2003.
  1. noyce
    noyce
    Aug 10, 2003
    179
    16
    England
    If i was to go for the panasonic ptae300 projector which supports progressive scan which dvd player would be a good choice to allow me to play my pal dvd's in progressive?
    Any help very much appreciated
  2. noyce
    noyce
    Aug 10, 2003
    179
    16
    England
    I'm in the search for the same thing so hopefully someone can help us out here! I'm in the process of having a standalone room built at the end of the garden and am desperately seeking some good signs (dolby digital etc)
    current setup: http://mysite.freeserve.com/noyce
  3. Noodle
    Noodle
    Jan 6, 2003
    577
    Peterborough
    The Harman Kardon DVD25 does NTSC & PAL prog scan I believe and retails at £350.
    This one.
    I've never seen it in action but it's apparently very good (WHF review).
  4. noyce
    noyce
    Aug 10, 2003
    179
    16
    England
    Cheers mate.Looks good. I notice were both from peterborough!
  5. Noodle
    Noodle
    Jan 6, 2003
    577
    Peterborough
    Peterboghorror.
    :eek:
  6. timlloyd
    timlloyd
    Jan 15, 2003
    278
    Warwick
    +9
    You want to check the dvd payers forum on here, there's loads of similar posts on this. Your current choices for mid range Pal Progressive are as follows though
    HK dvd 25 and 30 (£300 & £400)
    Philips 963 (£310)
    Sony 930 and 730 (£240 & £150)
    Marantz 2500? (£250)
    Yamaha S540 (£120)
    Hope this helps
    Tim
  7. noyce
    noyce
    Aug 10, 2003
    179
    16
    England
    Cheers mate. Is it worth spending a bit more or would i not notice that much of a difference going through an lcd projector?
  8. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    20,392
    In a secret location with Jennifer Lawrence
    +7,237
    Moved to DVD players forum.
    Greg
  9. calscot
    calscot
    Oct 29, 2002
    659
    16
    Milton Keynes
    Hold Everthing!
    JVC are about to release a Pal Prog DVD recorder for about £450 next month.
    The massive advantage is that you will be able to watch TV in progressive on your projector via component cables.
    This will be a vast improvement for watching live football and esecially Grand Prix on you big screen due to all the moving diagonal lines.
    It also means you can watch films straight off the telly, saving you renting or buying all the time.
    I already use my philips recorder for this but plan to upgrade to the JVC for the progressive scan.
    Cheers,
    Cal.
  10. noyce
    noyce
    Aug 10, 2003
    179
    16
    England
    Sounds good!:clap:
  11. calscot
    calscot
    Oct 29, 2002
    659
    16
    Milton Keynes
    Search for JVC DR-M1 to find out more or try .this thread for info from Rasczak.
    Cheers,
    Cal.
